MantisBT - ParaView
View Issue Details
0012610ParaView(No Category)public2011-09-21 16:572012-02-08 17:22
Kyle Lutz
Kyle Lutz
normalminorhave not tried
closedfixed
4.03.14
TBD
12610-unchecked-property-fixes
incorrect functionality
0012610: Fix handling of unchecked properties in pqPropertyLinks and pqSMAdaptor
No tags attached.
Issue History
2011-09-21 16:57Kyle LutzNew Issue
2011-09-21 16:57Kyle LutzAssigned To => Kyle Lutz
2011-09-21 17:01Kyle LutzStatusbacklog => todo
2011-09-21 17:01Kyle LutzStatustodo => active development
2011-09-22 08:41Kyle LutzNote Added: 0027515
2011-09-22 08:41Kyle LutzTopic Name => 12610-unchecked-property-fixes
2011-09-22 08:41Kyle LutzStatusactive development => gatekeeper review
2011-09-22 08:41Kyle LutzResolutionopen => fixed
2011-09-22 09:09Kyle LutzTarget Version => 4.0
2011-11-18 14:53Utkarsh AyachitFixed in Version => git-master
2011-11-18 14:54Utkarsh AyachitStatusgatekeeper review => customer review
2011-11-18 14:54Utkarsh AyachitNote Added: 0027721
2011-11-21 14:19Kyle LutzStatuscustomer review => closed
2012-02-08 17:22Utkarsh AyachitFixed in Versiongit-master => 3.14
Notes
(0027515)
Kyle Lutz
2011-09-22 08:41
Merge topic '12610-unchecked-property-fixes' into next
c6822fe Merge topic '12562-object-inspector-dock-widgets' into 12610-unchecked-property-fixes
0105b66 Pass type to getMultipleElementProperty() in pqSMAdaptor
69f4507 Fix bug in element count handling in pqSMAdaptor::getFileListProperty()
02ace8b Add call to sort list to fix issue in ExodusXML test
31f754d Fix order of SetElements() arguments
850ae23 Fix bug in pqSMAdaptor::getSelectionProperty()
4819a42 Use Type in pqSMAdaptor::getMultipleElementProperty()
209ad0e Add SetUncheckedElements() method to vector properties
a63b70b Rewrite pqPropertyManager using pqPropertyLinks directly
4aef5d9 Use ClearUncheckedProxies() instead of removing them
51fa55e Use UncheckedPropertyModifiedEvent in vtkSMProxyProperty
4e08687 Add vtkSMProxyProperty::ClearUncheckedProxies() method
4139bd0 Use propertyValueType in qtLinkedPropertyChanged()
5279909 Fix bug with reseting unchecked values
e7f93e0 Redo the pqSMAdaptor API using a flag for unchecked properties
4bbb900 Add vtkSMIntVectorProperty test
8c02e12 Add ClearUncheckedValues() method to vtkSMVectorProperty
305b89d Add support for proxys in GetProperty<vtkVariant>()
6f35f31 Add ClearUncheckedElements() method to vtkSMVectorProperty
7f0fcb6 Emit and listen to new UncheckedPropertyModfiedEvent
5541868 Update VTK to bring in UncheckedPropertyModifedEvent
77bc7dd Fix GetProperty() with vtkVariant for vtkSMPropertyHelper
40e759e Use unchecked properties in smLinkedPropertyChanged()
ce3ccc1 Add getUncheckedElementProperty() method to pqSMAdaptor
b669e46 Add getUncheckedMultipleElementProperty() methods to pqSMAdaptor
d96b04d Use vtkSMPropertyHelper in pqSMAdaptor
0570f8c Add vtkSMPropertyHelper::GetAsVariant() method
8856a9a Add vtkSMUncheckedPropertyHelper
560e8f3 Cleanup handling of proxy properties in vtkSMPropertyHelper
119736d Replace macros in vtkSMPropertyHelper with templates
531e32a Replace vtkSMPropertyHelper::GetAs*Ptr() methods with ones that return vector
300a93e Replace vtkSMPropertyHelperMin with std::min
cd3df9a Add vtkSMPropertyHelper constructor with vtkSMProperty argument
(0027721)
Utkarsh Ayachit
2011-11-18 14:54
merged to master.
