MantisBT - VTK | |||||
| View Issue Details | |||||
| 0012586 | VTK | (No Category) | public | 2011-09-10 07:34 | 2016-08-12 09:55 |
| Reporter | skific | ||||
| Assigned To | David Partyka | ||||
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | moved | ||
| Product Version | 5.8.0 | ||||
| Target Version | 5.8.1 | Fixed in Version | |||
| Project | TBD | ||||
| Type | incorrect functionality | ||||
| Summary | 0012586: vtkhdf5 include dirs for cpp build not present when HDF5_BUILD_CPP_LIB is ON | ||||
| Description | This happened when building vtk 5.8 (checkout from git tagged 5.8) in vs 2010 with cmake 2.8.5 I had enabled the HDF5_BUILD_CPP_LIB option in cmake-gui. However, the HDF5_INCLUDE_DIRS variable in vtkHDF5Config.cmake in buid/Utilities/vtkhdf5 does not hold the PATH_TO_VTK_SRC/Utilities/vtkhdf5/c++/src folder required for using hdf5's c++ classes. Consequently, the VTK_INCLUDE_DIRS variable has all vtkhdf5 folders, except for the c++/src folder. | ||||
| Steps To Reproduce | |||||
| Relationships | |||||
| Attached Files | |||||
| Issue History | |||||
| 2011-09-10 07:34 | skific | New Issue | |||
| 2011-09-12 10:08 | David Partyka | Assigned To | => David Partyka | ||
| 2011-09-12 10:08 | David Partyka | Status | backlog => tabled | ||
| 2011-09-14 14:37 | David Partyka | Status | tabled => backlog | ||
| 2011-09-14 14:37 | David Partyka | Product Version | => 5.8.0 | ||
| 2011-09-14 14:37 | David Partyka | Target Version | => 5.8.1 | ||
| 2013-07-22 20:33 | Dave DeMarle | Status | backlog => expired | ||
| 2013-07-22 20:33 | Dave DeMarle | Note Added: 0031284 | |||
| 2016-08-12 09:55 | Kitware Robot | Note Added: 0037243 | |||
| 2016-08-12 09:55 | Kitware Robot | Status | expired => closed | ||
| 2016-08-12 09:55 | Kitware Robot | Resolution | open => moved | ||
| Notes | |||||
