MantisBT - ParaView | |||||
View Issue Details | |||||
0012535 | ParaView | (No Category) | public | 2011-08-17 15:28 | 2016-08-12 09:58 |
Reporter | Ken Moreland | ||||
Product Version | |||||
Project | Sandia | ||||
Topic Name | |||||
Summary | 0012535: D3 divde cells mode broken | ||||
Description | The D3 filter has stopped working when in divide cells mode. To replicate, do the following: 1. Run ParaView client/server or multicore with 8 process. (Less will probably also cause the failure, but I haven't tried.) 2. Open the attached CurvedCylinder.vtu. Apply. 3. Run D3, change to Divide cells boundary mode. Apply. (Note that there is a separate modification bug with D3 where if you change the boundary mode after the first apply, the filter will not re-execute.) The result is wonky. (See the attached image.) This problem is not in ParaView 3.10, but it is in the latest master branch. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | CurvedCylinder.vtu (122,170) 2011-08-17 15:28 https://www.vtk.org/Bug/file/9006/CurvedCylinder.vtu CurvedCylinderD3.png (155,564) 2011-08-17 15:28 https://www.vtk.org/Bug/file/9007/CurvedCylinderD3.png | ||||
Issue History | |||||
2011-08-17 15:28 | Ken Moreland | New Issue | |||
2011-08-17 15:28 | Ken Moreland | File Added: CurvedCylinder.vtu | |||
2011-08-17 15:28 | Ken Moreland | File Added: CurvedCylinderD3.png | |||
2013-01-08 21:28 | Alan Scott | Project | TBD => Sandia | ||
2016-08-12 09:58 | Kitware Robot | Note Added: 0038049 | |||
2016-08-12 09:58 | Kitware Robot | Status | backlog => closed | ||
2016-08-12 09:58 | Kitware Robot | Resolution | open => moved | ||
Notes | |||||
