MantisBT - VTK | |||||
| View Issue Details | |||||
| 0012328 | VTK | (No Category) | public | 2011-07-01 16:52 | 2016-08-12 09:55 |
| Reporter | Jeff Mauldin | ||||
| Assigned To | Dave DeMarle | ||||
| Priority | high | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | moved | ||
| Product Version | |||||
| Target Version | Fixed in Version | ||||
| Project | Sandia | ||||
| Type | incorrect functionality | ||||
| Summary | 0012328: 'Show grid lines' for axes display draws lines outside bounding box on two axes | ||||
| Description | When you display the cube axis, and then go to the Edit Cube Axes Properties box, and turn on Show Grid Lines, the behavior is incorrect. For the X-Axis it seems to be okay. However, for the Y and Z Axes, the grid lines are drawn much beyond the range of the bounding box described by the cube axes lines. To demonstrate, simply start up paraview, create a cone source, turn on Show Cube Axes (in the Annotation section of the Display tab), hit the Edit button to bring up Edit Cube Axes Properties, go to the Y-Axis tab, select the Show Grid Lines check box, and hit okay. Same problem for the Z-Axis. okay for X-Axis. I suspect the error is connected with the following code in vtkCubeAxesActor.cxx in the method vtkCubeAxesActor::ComputeTickSize double xExt = 20; //bounds[1] - bounds[0]; double yExt = bounds[3] - bounds[2]; double zExt = bounds[5] - bounds[4]; although I haven't yet tried changing, I'm wondering why xExt is arbitrarily set to 20 rather than using the bounds. This also, I think affects the tick mark length in a bad way. I'm attaching state file. | ||||
| Steps To Reproduce | |||||
| Relationships | |||||
| Attached Files | https://www.vtk.org/Bug/file/8969/BadGridLines.pvsm | ||||
| Issue History | |||||
| 2011-07-01 16:52 | Jeff Mauldin | New Issue | |||
| 2011-07-01 16:52 | Jeff Mauldin | File Added: BadGridLines.pvsm | |||
| 2013-07-22 17:44 | Dave DeMarle | Note Added: 0031190 | |||
| 2013-07-22 17:44 | Dave DeMarle | Status | backlog => expired | ||
| 2013-07-22 17:44 | Dave DeMarle | Assigned To | => Dave DeMarle | ||
| 2016-08-12 09:55 | Kitware Robot | Note Added: 0037238 | |||
| 2016-08-12 09:55 | Kitware Robot | Status | expired => closed | ||
| 2016-08-12 09:55 | Kitware Robot | Resolution | open => moved | ||
| Notes | |||||
