MantisBT - ParaView | |||||
View Issue Details | |||||
0012317 | ParaView | (No Category) | public | 2011-06-27 03:53 | 2016-08-12 09:58 |
Reporter | Christoffer Green | ||||
Product Version | 3.10.1 | ||||
Project | TBD | ||||
Topic Name | |||||
Type | crash | ||||
Summary | 0012317: Particle Trace crash in linux | ||||
Description | This crash has been tested with: * 3.10.1 32 bit in linux 32 bit * 3.8.1 32 bit in linux 32/64 bit * 3.8.1 32 bit in windows 7 64 bit The crash happens in linux (we run ubuntu 10.10) but not in windows on both 3.8.1 and 3.10.1. I have attached a state file of the session as it appears before starting the animation (that leads to a crash in linux). We import an ensight .case file to an empty paraview state/scene. Add a temporal cache to it (so that the particle tracer can work with it). Add a source (it appears that any source will do but we use a point source). Connect the temporal cache as input and the point source as source to a ParticleTrace filter. When starting the animation paraview crashes after a little while. Unfortunately I cannot share the .case file but it contains a volume of velocity data and is a multi-block dataset. * Type: "Structured (Curvilinear) Grid" * Number of cells: 318291 * Number of points: 332800 * Memory: 7.8 MB * Dimensions: 80x80x52. Here is a python script session and a gdb backtrace that shows what we do and what crashes: #---- Trace output ----# try: paraview.simple except: from paraview.simple import * paraview.simple._DisableFirstRenderCameraReset() velocity_case = EnSightReader( CaseFileName='/mnt/Desktop/tmp/2_cc/velocity/velocity.case' ) AnimationScene1 = GetAnimationScene() velocity_case.PointArrays = ['V_3D_01'] AnimationScene1.EndTime = 2.0438699722290039 AnimationScene1.PlayMode = 'Snap To TimeSteps' RenderView1 = GetRenderView() DataRepresentation1 = Show() DataRepresentation1.Representation = 'Outline' DataRepresentation1.EdgeColor = [0.0, 0.0, 0.50000762951094835] RenderView1.CameraPosition = [0.017324004322290421, -0.036232437938451767, 0.73821731234013532] RenderView1.CameraClippingRange = [0.5690332866328488, 0.99442440740054638] RenderView1.CameraFocalPoint = [0.017324004322290421, -0.036232437938451767, -0.018334746360778809] RenderView1.CameraParallelScale = 0.19581008140331682 RenderView1.CenterOfRotation = [0.017324004322290421, -0.036232437938451767, -0.018334746360778809] TemporalCache1 = TemporalCache() DataRepresentation2 = Show() DataRepresentation2.Texture = [] DataRepresentation2.Representation = 'Outline' DataRepresentation2.EdgeColor = [0.0, 0.0, 0.50000762951094835] DataRepresentation1.Visibility = 0 PointSource1 = PointSource() DataRepresentation3 = Show() DataRepresentation3.EdgeColor = [0.0, 0.0, 0.50000762951094835] SetActiveSource(TemporalCache1) ParticleTracer1 = ParticleTracer( Source=PointSource1 ) ParticleTracer1.SelectInputVectors = ['POINTS', 'V_3D_01'] DataRepresentation4 = Show() DataRepresentation4.Texture = [] DataRepresentation4.EdgeColor = [0.0, 0.0, 0.50000762951094835] AnimationScene1.AnimationTime = 0.025871800258755684 AnimationScene1.StartTime = 0.025871800258755684 RenderView1.ViewTime = 0.025871800258755684 DataRepresentation2.Visibility = 0 DataRepresentation3.Visibility = 0 Render() ---------------- (gdb) bt #0 0xb793e932 in vtkDataArrayTemplate<float>::GetTuple (this=0xaee4ea8, i=-1, tuple=0xbfffc8b0) at /home/christoffer/Source/ParaView-3.8.1/VTK/Common/vtkDataArrayTemplate.txx:613 #1 0xb7ce96fe in vtkPoints::GetPoint (this=0x870a2b8, id=-1, x=0xbfffc8b0) at /home/christoffer/Source/ParaView-3.8.1/VTK/Common/vtkPoints.h:122 #2 0xb7ec15ae in vtkStructuredGrid::GetCell (this=0x9fcd430, cellId=-1, cell=0xa668708) at /home/christoffer/Source/ParaView-3.8.1/VTK/Filtering/vtkStructuredGrid.cxx:414 #3 0x0641bae0 in vtkCachingInterpolatedVelocityField::FunctionValues (this=0xa02a308, data=0x9fb12f8, x=0xaf40350, f=0xa02f494) at /home/christoffer/Source/ParaView-3.8.1/VTK/Parallel/vtkCachingInterpolatedVelocityField.cxx:280 #4 0x0641b616 in vtkCachingInterpolatedVelocityField::FunctionValues (this=0xa02a308, x=0xaf40350, f=0xa02f494) at /home/christoffer/Source/ParaView-3.8.1/VTK/Parallel/vtkCachingInterpolatedVelocityField.cxx:188 #5 0x06501aab in vtkTemporalInterpolatedVelocityField::TestPoint (this=0xa02f460, x=0xaf40350) at /home/christoffer/Source/ParaView-3.8.1/VTK/Parallel/vtkTemporalInterpolatedVelocityField.cxx:165 #6 0x06507c3a in vtkTemporalStreamTracer::TestParticles (this=0x8dce0b0, candidates=..., passed=..., count=@0xbfffcc5c) at /home/christoffer/Source/ParaView-3.8.1/VTK/Parallel/vtkTemporalStreamTracer.cxx:548 #7 0x06507ffe in vtkTemporalStreamTracer::AssignSeedsToProcessors (this=0x8dce0b0, source=0x9eb0338, sourceID=0, ptId=0, LocalSeedPoints=..., LocalAssignedCount=@0xbfffcc5c) at /home/christoffer/Source/ParaView-3.8.1/VTK/Parallel/vtkTemporalStreamTracer.cxx:621 #8 0x0650960a in vtkTemporalStreamTracer::RequestData (this=0x8dce0b0, inputVector=0xa039e80, outputVector=0xa030a58) at /home/christoffer/Source/ParaView-3.8.1/VTK/Parallel/vtkTemporalStreamTracer.cxx:923 0000009 0x065051df in vtkTemporalStreamTracer::ProcessRequest (this=0x8dce0b0, request=0x9f6b0b0, inputVector=0xa039e80, outputVector=0xa030a58) at /home/christoffer/Source/ParaView-3.8.1/VTK/Parallel/vtkTemporalStreamTracer.cxx:213 #10 0xb7d62105 in vtkExecutive::CallAlgorithm (this=0xa02e390, request=0x9f6b0b0, direction=1, inInfo=0xa039e80, outInfo=0xa030a58) at /home/christoffer/Source/ParaView-3.8.1/VTK/Filtering/vtkExecutive.cxx:747 0000011 0xb7d4af02 in vtkDemandDrivenPipeline::ExecuteData (this=0xa02e390, request=0x9f6b0b0, inInfo=0xa039e80, outInfo=0xa030a58) at /home/christoffer/Source/ParaView-3.8.1/VTK/Filtering/vtkDemandDrivenPipeline.cxx:507 #12 0xb7d1d3e4 in vtkCompositeDataPipeline::ExecuteData (this=0xa02e390, request=0x9f6b0b0, inInfoVec=0xa039e80, outInfoVec=0xa030a58) at /home/christoffer/Source/ParaView-3.8.1/VTK/Filtering/vtkCompositeDataPipeline.cxx:390 #13 0xb7d4a622 in vtkDemandDrivenPipeline::ProcessRequest (this=0xa02e390, request=0x9f6b0b0, inInfoVec=0xa039e80, outInfoVec=0xa030a58) at /home/christoffer/Source/ParaView-3.8.1/VTK/Filtering/vtkDemandDrivenPipeline.cxx:279 #14 0xb7eb6de4 in vtkStreamingDemandDrivenPipeline::ProcessRequest (this=0xa02e390, request=0x9f6b0b0, inInfoVec=0xa039e80, outInfoVec=0xa030a58) at /home/christoffer/Source/ParaView-3.8.1/VTK/Filtering/vtkStreamingDemandDrivenPipeline.cxx:202 #15 0xb7d1cb87 in vtkCompositeDataPipeline::ProcessRequest (this=0xa02e390, request=0x9f6b0b0, inInfoVec=0xa039e80, outInfoVec=0xa030a58) at /home/christoffer/Source/ParaView-3.8.1/VTK/Filtering/vtkCompositeDataPipeline.cxx:291 #16 0xb7d1c61d in vtkCompositeDataPipeline::ForwardUpstream (this=0xadeda10, request=0x9f6b0b0) at /home/christoffer/Source/ParaView-3.8.1/VTK/Filtering/vtkCompositeDataPipeline.cxx:214 #17 0xb7d4a58d in vtkDemandDrivenPipeline::ProcessRequest (this=0xadeda10, request=0x9f6b0b0, inInfoVec=0xade2f90, outInfoVec=0xadeda88) at /home/christoffer/Source/ParaView-3.8.1/VTK/Filtering/vtkDemandDrivenPipeline.cxx:265 #18 0xb7eb6de4 in vtkStreamingDemandDrivenPipeline::ProcessRequest (this=0xadeda10, request=0x9f6b0b0, inInfoVec=0xade2f90, outInfoVec=0xadeda88) at /home/christoffer/Source/ParaView-3.8.1/VTK/Filtering/vtkStreamingDemandDrivenPipeline.cxx:202 #19 0xb7d1cb87 in vtkCompositeDataPipeline::ProcessRequest (this=0xadeda10, request=0x9f6b0b0, inInfoVec=0xade2f90, outInfoVec=0xadeda88) at /home/christoffer/Source/ParaView-3.8.1/VTK/Filtering/vtkCompositeDataPipeline.cxx:291 #20 0xb7d1c61d in vtkCompositeDataPipeline::ForwardUpstream (this=0xaebb4e0, request=0x9f6b0b0) at /home/christoffer/Source/ParaView-3.8.1/VTK/Filtering/vtkCompositeDataPipeline.cxx:214 #21 0x045a6bcd in vtkPVCacheKeeperPipeline::ForwardUpstream (this=0xaebb4e0, request=0x9f6b0b0) at /home/christoffer/Source/ParaView-3.8.1/Servers/Filters/vtkPVCacheKeeperPipeline.cxx:55 #22 0xb7d4a58d in vtkDemandDrivenPipeline::ProcessRequest (this=0xaebb4e0, request=0x9f6b0b0, inInfoVec=0xaec0558, outInfoVec=0xaebba48) at /home/christoffer/Source/ParaView-3.8.1/VTK/Filtering/vtkDemandDrivenPipeline.cxx:265 #23 0xb7eb6de4 in vtkStreamingDemandDrivenPipeline::ProcessRequest (this=0xaebb4e0, request=0x9f6b0b0, inInfoVec=0xaec0558, outInfoVec=0xaebba48) at /home/christoffer/Source/ParaView-3.8.1/VTK/Filtering/vtkStreamingDemandDrivenPipeline.cxx:202 #24 0xb7d1cb87 in vtkCompositeDataPipeline::ProcessRequest (this=0xaebb4e0, request=0x9f6b0b0, inInfoVec=0xaec0558, outInfoVec=0xaebba48) at /home/christoffer/Source/ParaView-3.8.1/VTK/Filtering/vtkCompositeDataPipeline.cxx:291 #25 0xb7d4ad0a in vtkDemandDrivenPipeline::UpdateData (this=0xaebb4e0, outputPort=0) at /home/christoffer/Source/ParaView-3.8.1/VTK/Filtering/vtkDemandDrivenPipeline.cxx:449 #26 0xb7eb6fb2 in vtkStreamingDemandDrivenPipeline::Update (this=0xaebb4e0, port=0) at /home/christoffer/Source/ParaView-3.8.1/VTK/Filtering/vtkStreamingDemandDrivenPipeline.cxx:246 #27 0xb7d37502 in vtkDataObject::Update (this=0xaec3d98) at /home/christoffer/Source/ParaView-3.8.1/VTK/Filtering/vtkDataObject.cxx:1056 #28 0x0460e412 in vtkPVUpdateSuppressor::ForceUpdate (this=0xaebcd30) at /home/christoffer/Source/ParaView-3.8.1/Servers/Filters/vtkPVUpdateSuppressor.cxx:153 #29 0x041d6e6f in vtkPVUpdateSuppressorCommand (arlu=0x8267608, ob=0xaebcd30, method=0x9ea723d "ForceUpdate", msg=..., resultStream=...) at /home/christoffer/Source/ParaView-3.8.1-Bin/Servers/Filters/vtkPVUpdateSuppressorClientServer.cxx:89 #30 0x062e43ad in vtkClientServerInterpreter::ProcessCommandInvoke (this=0x8267608, css=..., midx=0) at /home/christoffer/Source/ParaView-3.8.1/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:378 #31 0x062e3b14 in vtkClientServerInterpreter::ProcessOneMessage (this=0x8267608, css=..., message=0) at /home/christoffer/Source/ParaView-3.8.1/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:213 #32 0x062e39d8 in vtkClientServerInterpreter::ProcessStream (this=0x8267608, css=...) at /home/christoffer/Source/ParaView-3.8.1/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:182 #33 0x04932a41 in vtkSelfConnection::ProcessStreamLocally (this=0x8870030, stream=...) at /home/christoffer/Source/ParaView-3.8.1/Servers/Common/vtkSelfConnection.cxx:118 #34 0x04932a00 in vtkSelfConnection::SendStreamToClient (this=0x8870030, stream=...) at /home/christoffer/Source/ParaView-3.8.1/Servers/Common/vtkSelfConnection.cxx:111 Thanks BR/ Christoffer | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | state.pvsm (164,594) 2011-06-27 03:53 https://www.vtk.org/Bug/file/8951/state.pvsm | ||||
Issue History | |||||
2011-06-27 03:53 | Christoffer Green | New Issue | |||
2011-06-27 03:53 | Christoffer Green | File Added: state.pvsm | |||
2016-08-12 09:58 | Kitware Robot | Note Added: 0037989 | |||
2016-08-12 09:58 | Kitware Robot | Status | backlog => closed | ||
2016-08-12 09:58 | Kitware Robot | Resolution | open => moved | ||
Notes | |||||
