MantisBT - ParaView | |||||
View Issue Details | |||||
0012130 | ParaView | Bug | public | 2011-04-27 16:56 | 2012-02-20 10:46 |
Reporter | Sven Buijssen | ||||
Assigned To | David Partyka | ||||
Priority | normal | Severity | minor | Reproducibility | always |
Status | closed | Resolution | fixed | ||
Product Version | Development | ||||
Target Version | Fixed in Version | 3.14 | |||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0012130: vtkSocket error on disconnect with AutoMPI enabled | ||||
Description | Development builds since PV commit 8a72f42e2a3817fe67745436e317c8e1cad9cfa2 (which pulled in also Burlen's vtkSocket fix for bug 12087) on Ubuntu 10.04.2 LTS 64 bit exhibit the following regression: built-in server, --disable-registry command line option * Edit / Settings / General / check "Use Multi-Core" / Ok * File / Disconnect => the following error message is raised: "ERROR: In /ParaView3.git/VTK/Common/vtkSocket.cxx, line 539 vtkSocket (0x2b34260): Socket error in call to close/closesocket. Bad file descriptor." | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | 0001-BUG-PV-bug-0012130-double-close-by-classes-derived-f.patch (1,976) 2011-05-02 18:40 https://www.vtk.org/Bug/file/8844/0001-BUG-PV-bug-0012130-double-close-by-classes-derived-f.patch | ||||
Issue History | |||||
2011-04-27 16:56 | Sven Buijssen | New Issue | |||
2011-05-02 18:40 | Burlen | File Added: 0001-BUG-PV-bug-0012130-double-close-by-classes-derived-f.patch | |||
2011-05-02 18:44 | Burlen | Note Added: 0026390 | |||
2011-05-03 06:33 | Sven Buijssen | Note Added: 0026423 | |||
2011-05-06 11:46 | Utkarsh Ayachit | Assigned To | => David Partyka | ||
2011-05-06 11:46 | Utkarsh Ayachit | Status | backlog => tabled | ||
2011-05-06 11:46 | Utkarsh Ayachit | Target Version | => 3.12 | ||
2012-02-20 10:46 | Utkarsh Ayachit | Note Added: 0028311 | |||
2012-02-20 10:46 | Utkarsh Ayachit | Status | backlog => closed | ||
2012-02-20 10:46 | Utkarsh Ayachit | Resolution | open => fixed | ||
2012-02-20 10:46 | Utkarsh Ayachit | Fixed in Version | => 3.14 |
Notes | |||||
