MantisBT - VTK
View Issue Details
0012115VTK(No Category)public2011-04-21 00:052016-08-12 09:55
David Gobbi
David Gobbi
normalminoralways
closedmoved
5.6.0
TBD
incorrect functionality
0012115: FixedPointRayCaster gives different results depending on number of threads
The dashboard test TestFixedPointRayCasterLinearCropped.tcl fails when run on machines with a large number of CPUs. The problem can be simulated on any machine by pumping up the number of threads.
Add the following lines to the beginning of TestFixedPointRayCasterLinearCropped.tcl
vtkMultiThreader multithread
multithread SetGlobalDefaultNumberOfThreads 64
Then run the test via ctest. It will produce an incorrect image.
No tags attached.
has duplicate 0013420closed Dave DeMarle Fixed point volume mapper gives inconsistent results on multiple threads
png TestFixedPointRayCasterLinearCropped.diff.png (4,969) 2011-04-21 00:05
https://www.vtk.org/Bug/file/8828/TestFixedPointRayCasterLinearCropped.diff.png
png
Issue History
2011-04-21 00:05David GobbiNew Issue
2011-04-21 00:05David GobbiFile Added: TestFixedPointRayCasterLinearCropped.diff.png
2013-02-24 12:59David GobbiRelationship addedhas duplicate 0013420
2013-05-28 12:13Dave DeMarleProject => TBD
2013-05-28 12:13Dave DeMarleType => incorrect functionality
2013-05-28 12:13Dave DeMarleNote Added: 0030859
2013-05-28 12:13Dave DeMarleStatusbacklog => todo
2013-05-28 12:13Dave DeMarleResolutionopen => fixed
2013-05-28 12:13Dave DeMarleAssigned To => Dave DeMarle
2013-05-28 12:13Dave DeMarleStatustodo => active development
2013-05-28 12:13Dave DeMarleStatusactive development => gatekeeper review
2013-07-10 10:17Dave DeMarleStatusgatekeeper review => todo
2013-07-10 10:17Dave DeMarleStatustodo => backlog
2013-07-10 10:18Dave DeMarleStatusbacklog => tabled
2013-07-10 10:18Dave DeMarleStatustabled => closed
2013-07-10 10:18Dave DeMarleProduct Version => 5.6.0
2013-07-10 10:18Dave DeMarleFixed in Version => 6.0.0
2014-01-17 14:35David GobbiAssigned ToDave DeMarle => David Gobbi
2014-01-17 14:35David GobbiNote Added: 0032185
2014-01-17 14:35David GobbiStatusclosed => backlog
2014-01-17 14:35David GobbiResolutionfixed => reopened
2014-01-17 14:38David GobbiNote Added: 0032186
2014-01-17 14:38David GobbiStatusbacklog => expired
2014-01-17 14:38David GobbiResolutionreopened => won't fix
2016-08-12 09:55Kitware RobotNote Added: 0037230
2016-08-12 09:55Kitware RobotStatusexpired => closed
2016-08-12 09:55Kitware RobotFixed in Version6.0.0 =>
2016-08-12 09:55Kitware RobotResolutionwon't fix => moved
Notes
(0030859)
Dave DeMarle
2013-05-28 12:13
Was fixed in commit: e4a793c47cc3
(0032185)
David Gobbi
2014-01-17 14:35
Re-opening the bug. It was reported as fixed, but it is still present.
(0032186)
David Gobbi
2014-01-17 14:38
Apparently attempts have been made to fix this bug, but none of the developers are interested in pursuing it any further.
(0037230)
Kitware Robot
2016-08-12 09:55
Resolving issue as `moved`.
This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page.
