MantisBT - ParaView |
View Issue Details |
0012046 | ParaView | Feature | public | 2011-04-05 09:06 | 2016-08-12 09:58 |
Reporter | Stephane P | |
Assigned To | Kitware Robot | |
Priority | normal | Severity | minor | Reproducibility | always |
Status | closed | Resolution | moved | |
Product Version | Development | |
Target Version | | Fixed in Version | | |
Project | ParaViS |
Topic Name | |
Type | |
Summary | 0012046: add a hint to specify representation of the output of a filter |
Description | Having a hint to specify the default rendering mode of the output of a filter defined in a plugin would be nice.
Even better would be the possibility to set the parameters of the representation in the hint. |
Steps To Reproduce | |
Additional Information | Usage example :
set the representation of the output of the "Generate Quadrature Points" filter to "Point Sprite", and set the "RadiusBy" property to the active scalar. |
Tags | No tags attached. |
Attached Files | |
2011-04-05 09:06 | Stephane P | New Issue | |
2011-06-23 11:43 | Utkarsh Ayachit | Project | => ParaViS |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037949 | |
