MantisBT - ParaView |
| View Issue Details |
| 0011923 | ParaView | Bug | public | 2011-03-03 11:46 | 2015-01-11 08:35 |
| Reporter | Madhura Phadke | |
| Assigned To | Utkarsh Ayachit | |
| Priority | normal | Severity | trivial | Reproducibility | always |
| Status | closed | Resolution | fixed | |
| Platform | Ubuntu | OS | Ubuntu | OS Version | 10.04 |
| Product Version | | |
| Target Version | 4.0 | Fixed in Version | 3.98.0 | |
| Project | TBD |
| Topic Name | 11923_fix_ffmpeg_fps_issues |
| Type | incorrect functionality |
| Summary | 0011923: Paraview 3.10 RC bits: unable to save animation |
| Description | I switched to Paraview 3.10.0 RC1 (downloaded from the website) and I get the following error when saving animation as a .avi file:
Generic Warning: In /home/kitware/Projects/ParaView-3.10/source/VTK/IO/vtkFFMPEGWriter.cxx, line 211
Could not open codec.
ERROR: In /home/kitware/Projects/ParaView-3.10/source/VTK/IO/vtkFFMPEGWriter.cxx, line 514
vtkFFMPEGWriter (0x12e902d0): Error initializing video stream.
I noticed this error only when I give frame rate >1. I am able to save animation successfully if I give frame rate as 1fps.
I am using Ubuntu 10.04, and I tried out saving animation of camera in orbit around the contour of a wavelet. |
| Steps To Reproduce | On Paraview 3.10 RC:
1. Create a source, and animate camera along the orbit.
2. Save animation using File Menu.
3. Select the options:
-Save as .avi file
-frame rate as 20 fps
| Additional Information | Reply from David Partyka to my email:
I can recreate this bug with my own binary but also discovered it seems to work if the frame rate is a power of 2 (2,4,8,16,32,..). I have a feeling something is going wrong possibly computing bit rates etc when initializing ffmpeg. Do you mind also reporting a bug on ParaView.org/Bug.
| Tags | No tags attached. |
| Relationships | |
| Attached Files | |
| Issue History |
| 2011-03-03 11:46 | Madhura Phadke | New Issue | |
| 2011-03-11 18:34 | Alan Scott | Note Added: 0025762 | |
| 2011-03-11 18:34 | Alan Scott | Note Added: 0025763 | |
| 2011-03-11 18:34 | Alan Scott | Target Version | => 3.10.1 |
| 2011-03-11 18:34 | Alan Scott | Description Updated | bug_revision_view_page.php?rev_id=251#r251 |
| 2011-03-31 11:24 | Utkarsh Ayachit | Target Version | 3.10.1 => 3.12 |
| 2012-02-29 09:41 | phsiao | Note Added: 0028328 | |
| 2012-10-19 02:42 | Joe Borg | Note Added: 0029434 | |
| 2012-10-24 11:07 | Utkarsh Ayachit | Project | => TBD |
| 2012-10-24 11:07 | Utkarsh Ayachit | Type | => incorrect functionality |
| 2012-10-24 11:07 | Utkarsh Ayachit | Target Version | => 4.0 |
| 2012-10-24 17:59 | Utkarsh Ayachit | Topic Name | => 11923_fix_ffmpeg_fps_issues |
| 2012-10-24 17:59 | Utkarsh Ayachit | Note Added: 0029507 | |
| 2012-10-24 17:59 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2012-10-24 17:59 | Utkarsh Ayachit | Fixed in Version | => git-next |
| 2012-10-24 17:59 | Utkarsh Ayachit | Resolution | open => fixed |
| 2012-10-24 17:59 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2012-10-29 10:50 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2012-10-29 10:50 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-10-29 10:50 | Utkarsh Ayachit | Note Added: 0029543 | |
| 2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
| 2013-01-11 14:11 | Alan Scott | Note Added: 0030101 | |
| 2013-01-11 14:11 | Alan Scott | Status | customer review => closed |
| 2015-01-09 13:47 | Dave DeMarle | Source_changeset_attached | => VTK master 3e4819c9 |
| 2015-01-09 13:48 | Dave DeMarle | Source_changeset_attached | => VTK master ecc05794 |
| 2015-01-09 13:48 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 7973caf8 |
| 2015-01-09 13:49 | Utkarsh Ayachit | Source_changeset_attached | => VTK master d9a0cdf3 |
| 2015-01-09 13:49 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 7850deb7 |
| 2015-01-11 08:35 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 60101e96 |
| 2015-01-11 08:35 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 6b6be702 |
(0025762)
Alan Scott
2011-03-11 18:34
This is still present in 3.10.0 release. |
(0025763)
Alan Scott
2011-03-11 18:34
(0028328)
phsiao
2012-02-29 09:41
This is still present in 3.14.0 release.
System Info:
Mac OS X 10.6.8
CMake 2.8.7
Qt 4.6.3
ffmpeg 0.6.1 and 0.6.5 |
(0029434)
Joe Borg
2012-10-19 02:42
I have the same issue on Linux and OSX |
(0029507)
Utkarsh Ayachit
2012-10-24 17:59
commit 7850deb7e5f17ab76de2a2ac07ef40d7b7234adf
Date: Wed Oct 24 17:56:07 2012 -0400
BUG 0011923. Fix computation of bit-rate-tolerance.
Bit rate tolerance was being computed incorrectly when FrameRate > 1. There is
no need to specify any bit-rate tolerance, so we simply use the default values,
unless overridden by the user.
Change-Id: If76321cc2689d64c6be98d23e561801f1d0bf41b |
(0029543)
Utkarsh Ayachit
2012-10-29 10:50
merged into master, if applicable. |
(0030101)
Alan Scott
2013-01-11 14:11
I am pretty sure this is fixed. If it is still an issue, please reopen the bug with details how to replicate it (such as what dataset/source to use).
Tested with can.exo, changed fps to 2 in save animation. Worked.
Tested Windows, local server, master. |
