MantisBT - ParaView | |||||
View Issue Details | |||||
0011762 | ParaView | Bug | public | 2011-01-26 03:49 | 2016-08-12 09:58 |
Reporter | Jens Kleimann | ||||
Priority | high | Severity | crash | Reproducibility | always |
Platform | Linux | OS | Linux | OS Version | 2.6.32-5-amd64 |
Product Version | 3.8.1 | ||||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0011762: Xdmf file with hyperslab itemtype crashes Paraview | ||||
Description | The attached file, which is supposed to cut a 2x2x2 cube out of a larger 3x3x3 cube, causes Paraview to crash. ("*** glibc detected *** ... realloc(): invalid next size: 0x0000000008e1a800 ***") To extract the subgrid [0,1]^3 from the larger [0,2]^3 grid, the start-stride-count in the first DataItem is set to 0 0 0 1 1 1 2 2 2 The same behavior occurs when trying to access the opposite corner [1,2]^3 (the one with values in the [8,15] range) using 1 1 1 1 1 1 2 2 2 instead. The crash can apparently be avoided using ranges whose count values are at least 3 (which should obviously be too large for the 2x2x2 target grid), and even grossly out-of-bound values such as 12 11 321 1 1 1 6 13 13 are accepted without complaints, and result in 1 2 0 3 4 0 0 0 i.e. a copy of the beginning of the source array. | ||||
Steps To Reproduce | Open Paraview, File->Open attached file "hyperslab_test.xmf", hit Apply. | ||||
Additional Information | I have also reported this prospective bug to Project Xdmf because it is unclear on which side the problem is. | ||||
Relationships | |||||
Attached Files | hyperslab_test.xmf (1,395) 2011-01-26 03:49 https://www.vtk.org/Bug/file/8658/hyperslab_test.xmf | ||||
Issue History | |||||
2011-01-26 03:49 | Jens Kleimann | New Issue | |||
2011-01-26 03:49 | Jens Kleimann | File Added: hyperslab_test.xmf | |||
2016-08-12 09:58 | Kitware Robot | Note Added: 0037913 | |||
2016-08-12 09:58 | Kitware Robot | Status | backlog => closed | ||
2016-08-12 09:58 | Kitware Robot | Resolution | open => moved | ||
Notes | |||||
