MantisBT - ParaView | |||||
View Issue Details | |||||
0011696 | ParaView | Feature | public | 2011-01-14 09:32 | 2016-08-12 09:58 |
Reporter | Stephane P | ||||
Priority | normal | Severity | minor | Reproducibility | N/A |
Product Version | Development | ||||
Project | ParaViS | ||||
Topic Name | |||||
Type | |||||
Summary | 0011696: add a hint tag to specify which array to use for default color of the output | ||||
Description | Add a "Hint" tag that can be used in the xml files to specify a given array (typically, this would point to the "ActiveScalars", "ActiveVectors"... ). This array will then be used to color the output by defaut. hard-coding the array name could aslo be supported. | ||||
Steps To Reproduce | |||||
Additional Information | typical xml could look like : <Hint> <ColorByAttribute attribute_association="point" <-- can be "point" or "cell" attribute_type="Vectors" <-- can be "Vectors" or "Scalars" attribute_name="blah" <-- hard code the array name / not compatible with the "attribute_type" tag. attribute_component="Magnitude"> <-- can be "Magnitude" (by default) or the component number </Hint> | ||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2011-01-14 09:32 | Stephane P | New Issue | |||
2011-01-14 09:43 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit | ||
2011-01-14 09:43 | Utkarsh Ayachit | Status | backlog => tabled | ||
2011-01-14 09:43 | Utkarsh Ayachit | Target Version | => 4.0 | ||
2011-06-16 13:10 | Zack Galbreath | Category | Feature Request => Feature | ||
2011-06-23 11:43 | Utkarsh Ayachit | Project | => ParaViS | ||
2016-08-12 09:58 | Kitware Robot | Note Added: 0037911 | |||
2016-08-12 09:58 | Kitware Robot | Status | backlog => closed | ||
Notes | |||||
