MantisBT - ParaView | ||||||||||
View Issue Details | ||||||||||
ID | Project | Category | View Status | Date Submitted | Last Update | |||||
0011549 | ParaView | Bug | public | 2010-12-01 11:22 | 2016-08-12 09:58 | |||||
Reporter | Ken Moreland | |||||||||
Assigned To | Kitware Robot | |||||||||
Priority | normal | Severity | minor | Reproducibility | have not tried | |||||
Status | closed | Resolution | moved | |||||||
Platform | Linux | OS | OpenSuse | OS Version | 11.3 | |||||
Product Version | ||||||||||
Target Version | Fixed in Version | |||||||||
Project | ||||||||||
Topic Name | ||||||||||
Type | ||||||||||
Summary | 0011549: Automatic values not set in object inspector when using forign language | |||||||||
Description | A user with OpenSuse 11.3 using a system language of German noticed some odd behavior while performing the Vector Visualization exercises in The ParaView Tutorial (exercises 2.9 and 2.10). When adding a filter that has an object inspector item that is automatically set, they were not set properly. For example, when creating a stream tracer filter, the radius of the seeds is set to 0 rather than to some value based on the size of the geometry. Likewise, when creating a glyph filter the scale factor is set to 0 rather than an automatic value based on the size of the geometry and the size of the vectors. I suspect that Qt is translating the name of the widgets, and then a latter comparison to a non-translated name is failing. | |||||||||
Steps To Reproduce | ||||||||||
Additional Information | ||||||||||
Tags | No tags attached. | |||||||||
Attached Files | ||||||||||
Issue History | ||||||||||
Date Modified | Username | Field | Change | |||||||
2010-12-01 11:22 | Ken Moreland | New Issue | ||||||||
2010-12-16 10:27 | Ken Moreland | Relationship added | related to 0011614 | |||||||
2016-08-12 09:58 | Kitware Robot | Note Added: 0037899 | ||||||||
2016-08-12 09:58 | Kitware Robot | Status | expired => closed | |||||||
2016-08-12 09:58 | Kitware Robot | Resolution | open => moved | |||||||
Notes | |||||
