MantisBT - ParaView | |||||
View Issue Details | |||||
0011322 | ParaView | Bug | public | 2010-10-16 05:29 | 2016-08-12 09:58 |
Reporter | Takuya OSHIMA | ||||
Priority | normal | Severity | minor | Reproducibility | always |
Product Version | Development | ||||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0011322: Client side plugin is loaded (reportedly) but does not work when Use Multi-Core is on | ||||
Description | ParaView git master as of 16/Oct/2010, OS X 10.6.4, Qt 4.7.0, GCC 4.2.1 (Apple Inc. build 5664). I have a client side plugin of my reader. It works fine in client/server mode and in builtin mode with the multi-core support turned off. However when Use Multi-Core in the Settings dialog is on, the plugin is shown as loaded in Plugin Manager but actually is not working at all (all GUI widgets that should be added by the plugin is missing from the reader panel). I can provide the whole source if it is needed. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2010-10-16 05:29 | Takuya OSHIMA | New Issue | |||
2016-08-12 09:58 | Kitware Robot | Note Added: 0037887 | |||
2016-08-12 09:58 | Kitware Robot | Status | expired => closed | ||
2016-08-12 09:58 | Kitware Robot | Resolution | open => moved | ||
Notes | |||||
