MantisBT - ParaView
View Issue Details
0010968ParaViewFeaturepublic2010-07-08 18:372013-11-01 13:18
Ken Moreland
David Thompson
highminorhave not tried
closedfixed
4.1
Sandia
10968_freezier_frozen_selection-rebased
incorrect functionality
0010968: Freeze Selection action in Find Data query dialog
One feature of importance that I see missing from the current Find Data query dialog box is a "freeze selection" action. I imagine a simple button that says Freeze Selection (or something better if you can think of it) that when clicked converts the current selection to an ID selection.
By default after you perform a query, the selected cells will change if you, for example, change the time and the queried fields change. That might be the desired behavior, but you might also desire to have those selected cells fixed and followed through time. To get the second case, a freeze selection button that converted the selection to IDs would do the trick.
When the selection is already an ID selection, the freeze selection button should be disabled.
No tags attached.
related to 0010958closed Utkarsh Ayachit Edit/Find data command - find and calculate min and max variable for each time step of an animation
child of 0010627closed David Thompson Additional functionality for find data
Issue History
2010-07-08 18:37Ken MorelandNew Issue
2010-07-08 18:37Ken MorelandRelationship addedchild of 0010627
2011-06-16 13:10Zack GalbreathCategoryFeature Request => Feature
2012-11-07 21:29Alan ScottNote Added: 0029661
2012-11-07 21:29Alan ScottStatusexpired => backlog
2012-11-07 21:29Alan ScottResolutionopen => reopened
2012-11-07 21:29Alan ScottStatusbacklog => todo
2012-11-07 21:29Alan ScottProject => Sandia
2012-11-07 21:29Alan ScottType => incorrect functionality
2012-11-07 21:29Alan ScottPrioritynormal => high
2012-12-11 09:44Sebastien JourdainAssigned To => David Thompson
2012-12-17 18:42David ThompsonRelationship addedrelated to 0010958
2012-12-31 23:05David ThompsonTopic Name => 10968_freeze_query_seln
2012-12-31 23:05David ThompsonNote Added: 0029967
2012-12-31 23:05David ThompsonStatustodo => gatekeeper review
2012-12-31 23:05David ThompsonFixed in Version => git-next
2012-12-31 23:05David ThompsonResolutionreopened => fixed
2013-01-04 14:45Utkarsh AyachitFixed in Versiongit-next => git-master
2013-01-04 14:46Utkarsh AyachitStatusgatekeeper review => customer review
2013-01-04 14:46Utkarsh AyachitNote Added: 0029980
2013-01-11 09:43Utkarsh AyachitStatuscustomer review => gatekeeper review
2013-01-11 14:43Utkarsh AyachitStatusgatekeeper review => customer review
2013-01-11 14:43Utkarsh AyachitNote Added: 0030107
2013-01-17 00:39David Thompson (old)Note Added: 0030174
2013-01-30 10:40Utkarsh AyachitFixed in Versiongit-master => 3.98.1
2013-02-26 16:00Alan ScottNote Added: 0030383
2013-05-23 13:10Alan ScottNote Added: 0030839
2013-05-23 13:10Alan ScottStatuscustomer review => todo
2013-07-03 12:21Kyle LutzTopic Name10968_freeze_query_seln => 10968_freezier_frozen_selection-rebased
2013-07-03 12:21Kyle LutzStatustodo => gatekeeper review
2013-07-03 12:21Kyle LutzFixed in Version3.98.1 => git-next
2013-07-12 14:07Utkarsh AyachitFixed in Versiongit-next => git-master
2013-07-12 14:07Utkarsh AyachitStatusgatekeeper review => customer review
2013-07-12 14:07Utkarsh AyachitNote Added: 0031128
2013-08-14 19:11Alan ScottNote Added: 0031454
2013-08-14 19:11Alan ScottStatuscustomer review => closed
2013-11-01 13:18Utkarsh AyachitFixed in Versiongit-master => 4.1
Notes
(0029661)
Alan Scott
2012-11-07 21:29
Work on the Find Data dialog is important, and being ignored.
(0029967)
David Thompson
2012-12-31 23:05
The branch named 10968_freeze_query_seln provides a way to "freeze" the current QUERY-based selection by converting it to an index-based (ID or GlobalID) selection. In this branch, the selection inspector properly converts a QUERY selection (i.e., one created using the Find Data dialog) into an indexed-based selection when the selection type is changed using the "Selection Type:" combo box. Previously, a new, blank index-based selection was created.
(0029980)
Utkarsh Ayachit
2013-01-04 14:46
merged into master, if applicable.
(0030107)
Utkarsh Ayachit
2013-01-11 14:43
merged into master, where applicable.
(0030174)
2013-01-17 00:39
This bug has 2 merges (1 for each of Utkarsh's notes above) because I forgot to add the "Freeze" button to the Find Data dialog as part of the first topic branch. The second topic merge adds the button. For the record, the merges from next to master are
http://paraview.org/gitweb?p=ParaView.git;a=commit;h=fdb7fa5c0d5bf19a1bb1762aeb86fcfc2ed4cb08 [^]
http://paraview.org/gitweb?p=ParaView.git;a=commit;h=2ce94ad0d8abb8a591f450678d4f3d5292f0643b [^]
The second SHA above shows when the topic that adds the button was merged to master.
(0030383)
Alan Scott
2013-02-26 16:00
Talked to Utkarsh. We think this bug can be closed, but we will wait until another bug/feature gets resolved - allowing the interactive selection and the Find Data dialog to be tied together. To test, you should be able to do the following:
* Open can.exo.
* Select cells through.
* Edit/ Find Data/ Freeze Selection (button).
(0030839)
Alan Scott
2013-05-23 13:10
Moving to ToDo, waiting on the last note above. Basically need to add frustrum selections (and all selections, whether they come from the find data dialog or not).
(0031128)
Utkarsh Ayachit
2013-07-12 14:07
merged into master.
(0031454)
Alan Scott
2013-08-14 19:11
Perfect.
Tested local server, master, Linux.
