MantisBT - ParaView |
| View Issue Details |
| 0010673 | ParaView | Bug | public | 2010-05-04 19:29 | 2010-07-07 10:02 |
| Reporter | Jon Woodring | |
| Assigned To | Robert Maynard | |
| Priority | normal | Severity | major | Reproducibility | always |
| Status | closed | Resolution | fixed | |
| Platform | | OS | | OS Version | |
| Product Version | | |
| Target Version | 3.8.1 | Fixed in Version | 3.8.1 | |
| Project | |
| Topic Name | |
| Type | |
| Summary | 0010673: CSV writer does not work with ghost cells and it writes char data as actual chars |
| Description | GIT as of 2010-05-04.
If your data set has ghost cells, it will write out the ghost cells, rather than culling them. This wouldn't be a problem if the vtkGhostLevel was correct. Though, the written field is not correct, and in my experience it is all 0s.
I can verify this against a VTU writer with the same data. A VTU writer does the correct thing, by culling ghost cells on output.
Additionally, if your data has a char field, it writes the data out as chars, rather than int strings, so if there is a 0, there is a null character in the output. |
| Steps To Reproduce | |
| Additional Information | |
| Tags | No tags attached. |
| Relationships | | related to | 0009869 | closed | Robert Maynard | Arrays of type char should be converted to ASCII numbers when written to CSV file |
| Attached Files | |
| Issue History |
| 2010-05-04 19:29 | Jon Woodring | New Issue | |
| 2010-05-05 09:47 | Ken Moreland | Relationship added | related to 0009869 |
| 2010-05-05 09:52 | Ken Moreland | Note Added: 0020582 | |
| 2010-05-05 12:10 | Jon Woodring | Note Added: 0020588 | |
| 2010-05-05 12:33 | Jon Woodring | Note Added: 0020589 | |
| 2010-05-05 13:11 | Jon Woodring | Note Added: 0020590 | |
| 2010-05-05 13:13 | Jon Woodring | Note Edited: 0020590 | |
| 2010-05-05 13:20 | Jon Woodring | Note Added: 0020591 | |
| 2010-05-05 13:52 | Ken Moreland | Note Added: 0020593 | |
| 2010-05-10 09:32 | Robert Maynard | Status | backlog => tabled |
| 2010-05-10 09:32 | Robert Maynard | Assigned To | => Robert Maynard |
| 2010-05-13 10:04 | Robert Maynard | Note Added: 0020732 | |
| 2010-05-13 10:21 | Robert Maynard | Note Deleted: 0020732 | |
| 2010-05-13 10:21 | Robert Maynard | Note Added: 0020733 | |
| 2010-05-13 10:21 | Robert Maynard | Status | tabled => @80@ |
| 2010-05-13 10:21 | Robert Maynard | Fixed in Version | => 3.8.2 |
| 2010-05-13 10:21 | Robert Maynard | Resolution | open => fixed |
| 2010-05-17 21:26 | Alan Scott | Note Added: 0020772 | |
| 2010-05-17 21:26 | Alan Scott | Status | @80@ => closed |
| 2010-06-15 09:45 | Utkarsh Ayachit | Fixed in Version | 3.8.2 => 3.8.1 |
| 2010-06-15 09:45 | Utkarsh Ayachit | Target Version | => 3.8.1 |
| 2010-07-07 09:55 | Utkarsh Ayachit | Fixed in Version | 3.8.1 => Development |
| 2010-07-07 10:02 | Utkarsh Ayachit | Note Added: 0021269 | |
| 2010-07-07 10:02 | Utkarsh Ayachit | Fixed in Version | Development => 3.8.1 |
(0020582)
Ken Moreland
2010-05-05 09:52
The writing out char arrays to a CSV file issue should be fixed (see 0009869). Are you sure you have the most recent version? |
(0020588)
Jon Woodring
2010-05-05 12:10
I cloned the git just yesterday, though I am new to git. Maybe I did something wrong. |
(0020589)
Jon Woodring
2010-05-05 12:33
I did a git pull and git submodule update, and recompiled. Is there anything else I need to do.
Also, here is a line from an offending CSV file, split by commas in python:
['16.1584', '362.783', '-1553.62', '1.92099e+09', '6945733', '\x00', '1246895', '199320', '-55.0512', '-23.4989', '-392.343', '671.647', '69.8461', '83.4789', '17.6399']
The sixth element is a null character, which corresponds to vtkGhostLevels.
Also, all of them are 0 for ghost level. Some should be different than 0 to mark ghost cells, if they are to be all output. |
(0020590)
Jon Woodring
2010-05-05 13:11
(edited on: 2010-05-05 13:13) |
I am uncertain about the ghost cell bug now. It appears that it may be correctly outputting vtkGhostLevels. I have to verify though, because of the cosmo data format wrap around on boundaries, is where I thought the bug was from.
Though, the char output (for vtkGhostLevels) is still there.
(0020591)
Jon Woodring
2010-05-05 13:20
It appears that ghost levels are fine, so I would ignore that part of the bug, but appears that somehow the char data as char bug as creeped back in.
vtkGhostLevels is unsigned char I believe, and not being output as a int string, but rather as an actual char in the output. |
(0020593)
Ken Moreland
2010-05-05 13:52
I just checked the behavior of writing a CVS file with a vtkValidPointMask, and that appears to be properly writing numbers instead of raw ASCII, so that fix still appears to be in effect. I don't know why it is treating vtkGhostLevels differently. |
(0020733)
Robert Maynard
2010-05-13 10:21
Needed to add a template specialization for unsigned char arrays.
ParaView commit SHA1: 4dba9d0d973a000e7adb5de7ebd98441c6848e8b |
(0020772)
Alan Scott
2010-05-17 21:26
(0021269)
Utkarsh Ayachit
2010-07-07 10:02
Verified that this is already in the "release" branch. |
