MantisBT - ParaView |
| View Issue Details |
| 0010627 | ParaView | Feature | public | 2010-04-27 21:04 | 2014-08-29 11:00 |
| Reporter | Alan Scott | |
| Assigned To | David Thompson | |
| Priority | normal | Severity | minor | Reproducibility | always |
| Status | closed | Resolution | fixed | |
| Platform | | OS | | OS Version | |
| Product Version | | |
| Target Version | 4.2 | Fixed in Version | 4.2 | |
| Project | Sandia |
| Topic Name | |
| Type | incorrect functionality |
| Summary | 0010627: Additional functionality for find data |
| Description | The Edit/ Find data command is a fabulous tool. However, it really needs a few more features.
* Checkbox that turns text on or off on the cell or point on the 3d view. Include the ability to display multiple pieces of data, such as cell global Id and temperature.
* Ability for the user to select (using the mouse or p key) on a cell or point, and have the data display. I.e., merging of the spreadsheet view (where you select data with a mouse) and the find data query results (where you select data with a keyboard).
* Allow the user to keep this dialog box up, and be able to interact with ParaView. This dialog should not be forced to close between uses.
* <<This one is manditory, and very important>> The ability to find the min and/or max variable, along with cell number, at a time step. Mean would be really nice to have also.
* Be able to take this min and/or max and display it in tabular format. Allow it to be 2d plotted. Allow it to be written out as a CSV file.
* Be able to plot/display/output all variables for these cells at a time.
<Usecase> I have a user that has a dataset that is in 512 files, and has to run on 8-32 cores/pvservers. His data has 800 timesteps, and 8 blocks. Within this data, he needs a .csv file output with the cell number, stress, pressure and temperature at the MAXIMUM temperature cell in each time step.
* Included - screenshot from the EnSight Select (They call it a Query) command. Notice the many, many ways they can do the query. Min, max, cursor, cell, or location. Notice that it is all in one place, on one screen.
* Included - screenshot from the EnSight Find data/ spreadsheet/ 2d plot command (don't ask, they call it Query under Plots). Takeaway here is that a user can plot the maximum temperature, etc, and also output the table of this data for all timesteps.
| Steps To Reproduce | |
| Additional Information | |
| Tags | No tags attached. |
| Relationships | | parent of | 0010954 | closed | David Thompson | Toolbar button for Find Data dialog | | parent of | 0010955 | closed | Alan Scott | Find/Edit data command - turn text on/off | | parent of | 0010956 | closed | Utkarsh Ayachit | Find/Edit data command - ability to click on a cell or point, highlighted on | | parent of | 0010958 | closed | Utkarsh Ayachit | Edit/Find data command - find and calculate min and max variable for each time step of an animation | | parent of | 0010957 | closed | Sebastien Jourdain | Edit/find data - allow dialog box to remain open | | parent of | 0010960 | closed | Sebastien Jourdain | Change query object in Find Data dialog box | | parent of | 0010961 | closed | Utkarsh Ayachit | Invert Selection does not work for Query selections | | parent of | 0010962 | closed | Utkarsh Ayachit | Find Data dialog should be populated with the current selection | | parent of | 0010968 | closed | David Thompson | Freeze Selection action in Find Data query dialog |
| Attached Files | junkScreenshot1.JPG (27,597) 2010-04-27 21:04 https://www.vtk.org/Bug/file/8069/junkScreenshot1.JPG
junkScreenshot2.JPG (218,696) 2010-04-27 21:05 https://www.vtk.org/Bug/file/8070/junkScreenshot2.JPG
| Issue History |
| 2010-04-27 21:04 | Alan Scott | New Issue | |
| 2010-04-27 21:04 | Alan Scott | File Added: junkScreenshot1.JPG | |
| 2010-04-27 21:05 | Alan Scott | File Added: junkScreenshot2.JPG | |
| 2010-04-27 21:06 | Alan Scott | Target Version | => 3.10 |
| 2010-07-08 12:33 | Alan Scott | Relationship added | parent of 0010954 |
| 2010-07-08 12:34 | Alan Scott | Relationship added | parent of 0010955 |
| 2010-07-08 12:34 | Alan Scott | Relationship added | parent of 0010956 |
| 2010-07-08 12:35 | Alan Scott | Relationship added | parent of 0010958 |
| 2010-07-08 12:36 | Alan Scott | Relationship added | parent of 0010957 |
| 2010-07-08 14:53 | Ken Moreland | Relationship added | parent of 0010960 |
| 2010-07-08 15:06 | Ken Moreland | Relationship added | parent of 0010961 |
| 2010-07-08 15:17 | Ken Moreland | Relationship added | parent of 0010962 |
| 2010-07-08 18:37 | Ken Moreland | Relationship added | parent of 0010968 |
| 2011-06-16 13:10 | Zack Galbreath | Category | Feature Request => Feature |
| 2012-09-20 17:15 | Alan Scott | Assigned To | => Alan Scott |
| 2012-09-20 17:15 | Alan Scott | Note Added: 0029239 | |
| 2012-09-20 17:15 | Alan Scott | Status | expired => backlog |
| 2012-09-20 17:15 | Alan Scott | Resolution | open => reopened |
| 2012-10-23 21:00 | Alan Scott | Assigned To | Alan Scott => |
| 2012-10-23 21:05 | Alan Scott | Project | => Sandia |
| 2012-10-23 21:05 | Alan Scott | Type | => incorrect functionality |
| 2012-11-07 21:30 | Alan Scott | Note Added: 0029662 | |
| 2012-11-07 21:30 | Alan Scott | Status | backlog => todo |
| 2012-12-11 09:43 | Sebastien Jourdain | Assigned To | => David Thompson |
| 2014-01-16 17:01 | Utkarsh Ayachit | Note Added: 0032183 | |
| 2014-01-16 17:01 | Utkarsh Ayachit | Status | todo => gatekeeper review |
| 2014-01-16 17:01 | Utkarsh Ayachit | Resolution | reopened => fixed |
| 2014-01-20 10:00 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2014-01-20 10:01 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2014-01-20 10:01 | Utkarsh Ayachit | Note Added: 0032190 | |
| 2014-02-04 21:51 | Alan Scott | Note Added: 0032275 | |
| 2014-02-04 21:51 | Alan Scott | Status | customer review => closed |
| 2014-06-17 09:22 | Utkarsh Ayachit | Target Version | => 4.2 |
| 2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
(0029239)
Alan Scott
2012-09-20 17:15
Bringing back to backlog. |
(0029662)
Alan Scott
2012-11-07 21:30
This is sort of the parent of numerous important bugs. Thus, I am marking as todo. |
(0032183)
Utkarsh Ayachit
2014-01-16 17:01
Resolving this since we have addressed several of these issues and those that were not addressed are opened up as separate issues. |
(0032190)
Utkarsh Ayachit
2014-01-20 10:01
SUMMARY
Topics merged into master:
14487_fix_segfault
14496_fix_tracing_of_subproxies
pvweb-add-webtest-setup-doc
pvweb-quick-start-doc-update
(0032275)
Alan Scott
2014-02-04 21:51
Sounds good, as per Utkarsh's note. Closing. |
