MantisBT - ParaView | |||||
| View Issue Details | |||||
| 0010488 | ParaView | Bug | public | 2010-03-30 09:49 | 2011-05-17 20:35 |
| Reporter | David Doria | ||||
| Assigned To | Utkarsh Ayachit | ||||
| Priority | normal | Severity | minor | Reproducibility | always |
| Status | closed | Resolution | fixed | ||
| Product Version | Development | ||||
| Target Version | Fixed in Version | 3.12 | |||
| Project | |||||
| Topic Name | |||||
| Type | |||||
| Summary | 0010488: XML plugins not loaded at startup | ||||
| Description | I added some paths to my PV_PLUGIN_PATH. When I start Paraview, in the plugin manager I see the .so plugins in those paths, but not the .xml plugins. Bu ".so plugin" I mean I have a .h, .cxx, and .xml file that I have compiled into a .so file. By ".xml plugin" I ONLY have a .xml file that is using existing vtk .cxx/.h files. In the plugin manager, when you load a new plugin, you have to change the file type drop down box to ".xml" to load an xml file directly. | ||||
| Steps To Reproduce | |||||
| Relationships | |||||
| Attached Files | |||||
| Issue History | |||||
| 2010-03-30 09:49 | David Doria | New Issue | |||
| 2011-05-09 17:13 | Utkarsh Ayachit | Note Added: 0026473 | |||
| 2011-05-09 17:13 | Utkarsh Ayachit | Status | backlog => @80@ | ||
| 2011-05-09 17:13 | Utkarsh Ayachit | Fixed in Version | => 3.12 | ||
| 2011-05-09 17:13 | Utkarsh Ayachit | Resolution | open => fixed | ||
| 2011-05-09 17:13 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit | ||
| 2011-05-17 20:35 | Alan Scott | Note Added: 0026527 | |||
| 2011-05-17 20:35 | Alan Scott | Status | @80@ => closed | ||
| Notes | |||||
