MantisBT - ParaView | |||||
| View Issue Details | |||||
| 0010394 | ParaView | Bug | public | 2010-03-09 09:15 | 2010-03-23 21:42 |
| Reporter | olesen | ||||
| Assigned To | David Partyka | ||||
| Priority | normal | Severity | minor | Reproducibility | always |
| Status | closed | Resolution | fixed | ||
| Product Version | Development | ||||
| Target Version | Fixed in Version | ||||
| Project | |||||
| Topic Name | |||||
| Type | |||||
| Summary | 0010394: Development install tree cannot be used to build plugin. | ||||
| Description | For the "hard-test" with PARAVIEW_INSTALL_DEVELOPMENT turned on. - make && make install - relocate the built tree somewhere else - rename the source tree to another name (to check if the source tree really isn't needed). After doing this, and setting ParaView_DIR to point to the new location, building a separate plugin still fails, due to the following bits from the plug CMakeLists.txt: FIND_PACKAGE(ParaView REQUIRED) INCLUDE(${PARAVIEW_USE_FILE}) The $ParaView_DIR/ParaViewConfig.cmake is found and it contains references to the now non-existent paraview source directory. If I move $ParaView_DIR/ParaViewConfig.cmake out of the way, the $ParaView_DIR/lib/paraview-3.7/ParaViewConfig.cmake file is correctly found and the build succeeds. | ||||
| Steps To Reproduce | |||||
| Relationships | |||||
| Attached Files | |||||
| Issue History | |||||
| 2010-03-09 09:15 | olesen | New Issue | |||
| 2010-03-09 09:18 | David Partyka | Status | backlog => tabled | ||
| 2010-03-09 09:18 | David Partyka | Assigned To | => David Partyka | ||
| 2010-03-16 18:17 | David Partyka | Note Added: 0019916 | |||
| 2010-03-17 04:51 | olesen | Note Added: 0019920 | |||
| 2010-03-17 08:47 | David Partyka | Note Added: 0019923 | |||
| 2010-03-17 08:47 | David Partyka | Status | tabled => @80@ | ||
| 2010-03-17 08:47 | David Partyka | Resolution | open => fixed | ||
| 2010-03-23 21:41 | Alan Scott | Note Added: 0019992 | |||
| 2010-03-23 21:41 | Alan Scott | Status | @80@ => closed | ||
| Notes | |||||
