(0019762)
Utkarsh Ayachit
2010-03-08 15:30
Looks like the label disappearing happened because of "Log scale for bottom" axes.
However the weird behavior is this:
* I opened a XY plot, check log scale for bottom axis.
* I deleted that view. Created a new one--by default showed up without Log scale for x axis- which is good. But now when I go to view settings, the log-scale option of the bottom axis is already checked (guess it remembered) and hitting "Apply" resulted in changing to log scale without my explicit knowledge. |
(0019822)
Marcus D. Hanwell
2010-03-10 17:48
Partial fix in Qt/Components/pqXYChartOptionsEditor.cxx 1.7, for the loading of the log scale property and the refresh of the axes pages. The label positions will be follow. |
(0019847)
Marcus D. Hanwell
2010-03-11 16:52
Added some code to position the axis labels correctly, VTK/Charts/vtkAxis.cxx 1.19, I need to do some more work to request the entire chart is laid out again once font metrics determine the appropriate amount of space needed for each axis.. |
(0020697)
Marcus D. Hanwell
2010-05-10 13:33
So the major issues here are resolved, with some related issues in the bug I marked this a duplicate of. |
(0020807)
Alan Scott
2010-05-21 14:09
I believe that the labels are now correctly positioned, but they are not the same color as other axis. All axis labels should be the same color, unless the user specifically changes them.
If you want to resolve this bug, and have me open another bug for color, let me know.
Alan |
(0020809)
Marcus D. Hanwell
2010-05-21 14:21
Ah, I think I copied the defaults from the old charts. It is a simple change in the XML...commit 45c78c2 contains the change. Please let me know if this is what you wanted. |
(0020888)
Alan Scott
2010-06-01 21:16
Tested local server, Windows, trunk. |
