MantisBT - ParaView
View Issue Details
0010317ParaViewBugpublic2010-02-22 15:132011-01-13 17:00
Ken Moreland
Utkarsh Ayachit
normalminorhave not tried
closedfixed
3.83.8
0010317: Cannot save VTK hierarchical box file when running in parallel
When you have an AMR data set loaded in parallel (from, for example, a spyplot file), there does not seem to be a way to save it. The file browser claims that you can save it out in the VTK hierarchical box format, but when you try to do that you get a bunch of errors and nothing is written out.
Note that if all of the data happens to be on node 0 and all other nodes are empty, then the file write works. This, of course, is no use in general.
No tags attached.
Issue History
2010-02-22 15:13Ken MorelandNew Issue
2010-02-22 15:13Ken MorelandTarget Version => 3.8
2010-03-04 16:45Utkarsh AyachitStatusbacklog => tabled
2010-03-04 16:45Utkarsh AyachitAssigned To => Utkarsh Ayachit
2010-03-07 13:57Utkarsh AyachitNote Added: 0019753
2010-03-07 13:57Utkarsh AyachitStatustabled => @80@
2010-03-07 13:57Utkarsh AyachitFixed in Version => 3.8
2010-03-07 13:57Utkarsh AyachitResolutionopen => fixed
2010-03-10 21:36Alan ScottNote Added: 0019824
2010-03-10 21:36Alan ScottStatus@80@ => closed
2011-01-13 17:00Source_changeset_attached => VTK master a2bd8391
2011-01-13 17:00Source_changeset_attached => VTK master 020ef709
Notes
(0019753)
Utkarsh Ayachit
2010-03-07 13:57
The datastructures were not synced correctly across
processes when writing AMR. Fixed that.
/cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLCompositeDataWriter.cxx,v <-- VTK/IO/vtkXMLCompositeDataWriter.cxx
new revision: 1.9; previous revision: 1.8
/cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLCompositeDataWriter.h,v <-- VTK/IO/vtkXMLCompositeDataWriter.h
new revision: 1.6; previous revision: 1.5
/cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLHierarchicalBoxDataWriter.cxx,v <-- VTK/IO/vtkXMLHierarchicalBoxDataWriter.cxx
new revision: 1.8; previous revision: 1.7
/cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLHierarchicalBoxDataWriter.h,v <-- VTK/IO/vtkXMLHierarchicalBoxDataWriter.h
new revision: 1.3; previous revision: 1.2
/cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkXMLPHierarchicalBoxDataWriter.cxx,v <-- VTK/Parallel/vtkXMLPHierarchicalBoxDataWriter.cxx
new revision: 1.5; previous revision: 1.4
(0019824)
Alan Scott
2010-03-10 21:36
Tested remote servers, XP, trunk.
Used Dave's medium dataset, wrote out vtk format, then read it back in.
