MantisBT - ParaView | |||||
| View Issue Details | |||||
| 0010125 | ParaView | Bug | public | 2010-01-12 10:17 | 2016-08-12 09:57 |
| Reporter | Berk Geveci | ||||
| Assigned To | Kitware Robot | ||||
| Priority | normal | Severity | minor | Reproducibility | always |
| Status | closed | Resolution | moved | ||
| Product Version | |||||
| Target Version | Fixed in Version | ||||
| Project | |||||
| Topic Name | |||||
| Type | |||||
| Summary | 0010125: The ParaView extent translator is causing problems with imaging pipeline | ||||
| Description | Currently, if an Image source has a certain Extent, Paraview will pass that as UPDATE_EXTENT to all subsequent filters in the pipeline, even if a filter changes the whole extent. This prohibits for example implementing vtkImageConstantPad as a useful Paraview filter. For further info see http://markmail.org/message/sfnw7sgojytzw6y2 [^] . I am sure this has something to do with the fact that ParaView uses its own extent translator that uses the reader's extents. | ||||
| Steps To Reproduce | |||||
| Relationships | |||||
| Attached Files | |||||
| Issue History | |||||
| 2010-01-12 10:17 | Berk Geveci | New Issue | |||
| 2010-06-03 04:57 | Jerome Velut | Note Added: 0020902 | |||
| 2010-06-03 07:12 | Jerome Velut | Note Edited: 0020902 | |||
| 2016-08-12 09:57 | Kitware Robot | Note Added: 0037764 | |||
| 2016-08-12 09:57 | Kitware Robot | Status | expired => closed | ||
| 2016-08-12 09:57 | Kitware Robot | Resolution | open => moved | ||
| 2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot | ||
| Notes | |||||
