ParaView - Change Log
ParaView - 3.98.1 (Released 2013-02-07) View Issues ]
- 0013231: Heap corruption when vtkTables are deleted but view remains (Utkarsh Ayachit) - closed.
- 0013473: Variable name change to Material volume fraction in CTH (Utkarsh Ayachit) - closed.
- 0013674: Fix issues with Qt-based static plugins (Utkarsh Ayachit) - closed.
- 0013726: Extreme slowness turning on all variables (Utkarsh Ayachit) - closed.
- 0013740: Selection Inspector - Cell Label - data is incorrect remote server. (Utkarsh Ayachit) - closed.
- 0013742: Selection Inspector - Cell Label - text doesn't follow selection (Utkarsh Ayachit) - closed.
- 0013818: Need ability to set min and max range for 2d axes (Utkarsh Ayachit) - closed.
- 0013311: Time marker for Plots no longer working (Utkarsh Ayachit) - closed.
- 0013374: Multiple Modes for SLAC Reader (Ken Moreland) - closed.
- 0013675: Update mpi4py to the latest version available (Nikhil Shetty) - closed.
- 0013729: Add tooltips to Adjust Camera (Utkarsh Ayachit) - closed.
- 0013739: Group select of variables no longer works (Utkarsh Ayachit) - closed.
- 0013746: Pipeline change input crash (Utkarsh Ayachit) - closed.
- 0013747: Fix mountain lion runtime issues (Utkarsh Ayachit) - closed.
- 0013748: Exodus reader refresh button is missing (Utkarsh Ayachit) - closed.
- 0013753: Properties search should always show advanced properties (Utkarsh Ayachit) - closed.
- 0013757: String arrays with whitespace endup showing up with weird separation in SpreadSheet view (Utkarsh Ayachit) - closed.
- 0013766: Error reading files with small timesteps (Utkarsh Ayachit) - closed.
- 0013784: Show axis and Show Axis Grid do nothing (Utkarsh Ayachit) - closed.
- 0013799: Comparitive view doesn't show variables correctly. (Utkarsh Ayachit) - closed.
- 0013811: 3D Widgets staying visible when active panel is changed. (Utkarsh Ayachit) - closed.
- 0013817: Segfaults/Hangs when rendering streamlines with translucent surfaces in parallel (Utkarsh Ayachit) - closed.
- 0013821: vtkRenderingFreeTypeObjectFactory leaks in release builds of ParaView (Utkarsh Ayachit) - closed.
- 0013696: [Feature] Add mobile remote control plugin to ParaView (Sebastien Jourdain) - closed.
- 0013782: Text doesn't update remote server (Utkarsh Ayachit) - closed.
- 0013806: Remove min/max/mean from Find Data for next release. (Utkarsh Ayachit) - closed.
- 0013809: EyeDomeLighting Plugin segfault when saving animations in client-server mode. (Utkarsh Ayachit) - closed.
- 0013824: Calculator disabled when no point or cell data exists. (Utkarsh Ayachit) - closed.
- 0013826: Matplotlib broken in mac packages (David C. Lonie) - closed.
- 0013830: Disable progress over 64 nodes. (Utkarsh Ayachit) - closed.
- 0013863: Visibility animation not working correctly (Utkarsh Ayachit) - closed.
- 0012966: .plugins file needed on server side (Alan Scott) - closed.
- 0013777: Lock Interactive Render no longer functions (Nikhil Shetty) - closed.
- 0013470: Hang - CTH AMR and Outline Corners (Nikhil Shetty) - closed.
- 0013673: Enable point-sprite plugin for shared builds (Utkarsh Ayachit) - closed.
- 0013786: Enable serial use of the WindBlade reader in ParaView (Andy Bauer) - closed.
- 0013814: rescale to data range option for generated co-processing scripts doesn't work in parallel (Andy Bauer) - closed.
- 0013734: [Superbuild] Paraview 3.98 does not export to animation to avi on Mountain Lion (Utkarsh Ayachit) - closed.
- 0013760: Crash when trying to change MantaView settings (patch attached) (Dave DeMarle) - closed.
- 0013788: Can't interrupt paraview (David C. Lonie) - closed.
- 0013789: Matplotlib fails to work when run with a space in argv[0] on mac. (David C. Lonie) - closed.
- 0013790: Add option to show server window without borders to PVX file (David C. Lonie) - closed.
- 0013803: Merge changes to VR plugin (David C. Lonie) - closed.
- 0013822: vtkVRGrabWorldStyle doesn't update display (David C. Lonie) - closed.
- 0013825: VR plugin missing vtkObjectFactory includes. (David C. Lonie) - closed.
- 0013846: Repeated text in GL2PS export dialog (David C. Lonie) - closed.
- 0013847: MathText is displayed with a freetype bounding box (David C. Lonie) - closed.
- 0013848: PDF export renders mathtext via freetype. (David C. Lonie) - closed.
- 0013862: Fix typo in VRUIConnection (David C. Lonie) - closed.
- 0013850: UpdatePipeline(time) in paraview python doesn't update properly for writers (Andy Bauer) - closed.
- 0013587: MPIPython fails to build on certain Macs (Nikhil Shetty) - closed.
- 0013056: Selection with Crtl key not possible (Utkarsh Ayachit) - closed.
- 0013553: [git/master] VisItBridge GMVReader does on Windows not support reading ASCII files with only linefeed endings - closed.
- 0013554: [git/master] VisItBridge GMVReader does not support reading valid unstructured grid file without cell information (Sebastien Jourdain) - closed.
- 0013557: [git/master] VisItBridge GMVReader can trigger null pointer dereference in gmvread.c - closed.
- 0013558: [git/master] VisItBridge GMVReader + comment line length > 99: null pointer dereference in gmvread.c - closed.
- 0013578: Non free licenses in paraview 3.14.0 (Philippe P├ębay) - closed.
- 0013584: AutoMPI- Add option to select number of cores (Nikhil Shetty) - closed.
- 0013599: [git/master] VisItBridge GMVReader: segfault while reading GMV file with broken fromfile reference - closed.
- 0013608: Add a toolbar for Data Analysis plots (David Thompson) - closed.
- 0013634: [git/master] VisItBridge GMVReader's gmvread.c: stack smashing while parsing file with polygonal data - closed.
- 0013635: [git/master] VisItBridge GMVReader does on Windows not support absolute paths in "fromfiles" - closed.
- 0013654: cmake error configuring pvblot plugin (Nikhil Shetty) - closed.
- 0013672: Patch visit bridge cgns reader (Robert Maynard) - closed.
- 0013693: CheckFortran.cmake was removed from the SuperBuild subdirectory and causes problems with CoProcessing's FortranAdaptors (Andy Bauer) - closed.
- 0013694: aesthetic adjustments to the memory inspector (Burlen) - closed.
- 0013713: fit to screen option hidden in co-processing plugin's export wizard. (Andy Bauer) - closed.
- 0013716: co-processing plugin script can't do live in-situ with views (Andy Bauer) - closed.
- 0013723: Auto Accept (under Edit/ Settings) doesn't work (Kyle Lutz) - closed.
- 0013727: improve co-processing testing (Andy Bauer) - closed.
- 0013756: ParaView binaries not building on Windows (Utkarsh Ayachit) - closed.
- 0013759: Move support for testing nightly binaries to ParaViewSuperbuild from ParaView (Utkarsh Ayachit) - closed.
- 0013762: Fix matplotlib in apple bundles. (David C. Lonie) - closed.
- 0013767: Remove PARAVIEW_USE_MATPLOTLIB cmake option (David C. Lonie) - closed.
- 0013768: Add custom geometry tag to Machine entries in .pvx files (David C. Lonie) - closed.
- 0012473: Python tests randomly fail on windows (Robert Maynard) - closed.
- 0013598: Account for camera in GrabWorld VR interaction style (David C. Lonie) - closed.
- 0013629: Variable selection (Utkarsh Ayachit) - closed.
- 0013677: GMVReaderBasicRead test fails (Kyle Lutz) - closed.
- 0013691: [Bug] co-processing tests not launched with mpirun (Andy Bauer) - closed.
- 0013724: Edit/ Settings/ Auto Accept named wrong (Kyle Lutz) - closed.
- 0013738: Disabling matplotlib doesn't. (David C. Lonie) - closed.
- 0013765: missing Particle Pathlines filter in paraview (Leo Liu) - closed.
- 0013769: Contour filter "Compute scalars" misbehaves (Andy Bauer) - closed.
- 0013779: vtkProxy::UpdateSelfAndAllInputs() doesn't behave as expected. (Utkarsh Ayachit) - closed.
- 0013780: Catalyst updates (Chris Harris) - closed.
- 0013785: pypv.(FileSeries|NonlinearSubdivisionDisplay|TestContourWidget) tests fail with segfault (Kyle Lutz) - closed.
- 0013787: Make properties panel button slots public (Kyle Lutz) - closed.
- 0013795: Chart axes (right side) goes bad (Marcus D. Hanwell) - closed.
- 0013796: Chart axes (left and right side) are out of sync (Marcus D. Hanwell) - closed.
[90 issues]
Powered by Mantis Bugtracker
