0015196 | VTK | (No Category) | public | 2014-12-10 05:26 | 2015-02-05 14:14 | ||||
Reporter | Nicholas Yue | ||||||||
Assigned To | Jean-Christophe Fillion-Robin | ||||||||
Product Version | 6.0.0 | ||||||||
Target Version | Fixed in Version | 6.2.0 | |||||||
Summary | 0015196: VTK 6.1 OS X Yosemite - Cocoa garbage collection | ||||||||
Description | Using the /usr/bin/c++ which has the following version information c++ --version Apple LLVM version 6.0 (clang-600.0.54) (based on LLVM 3.5svn) Target: x86_64-apple-darwin14.0.0 Thread model: posix I have been unable to build VTK 6.1 due to Cocoa changes in Yosemite, specifically, the following errors surfaced [ 22%] Building CXX object Rendering/OpenGL/CMakeFiles/vtkRenderingOpenGL.dir/vtkCocoaRenderWindowInteractor.mm.o error: garbage collection is no longer supported make[2]: *** [Rendering/OpenGL/CMakeFiles/vtkRenderingOpenGL.dir/vtkCocoaRenderWindowInteractor.mm.o] Error 1 make[1]: *** [Rendering/OpenGL/CMakeFiles/vtkRenderingOpenGL.dir/all] Error 2 make: *** [all] Error 2 | ||||||||
Project | TBD | ||||||||
(0034164) Dave DeMarle (administrator) 2015-02-05 12:19 |
Nicolas, We have a couple of yosemite dashboard submitters. Check their configurations (https://open.cdash.org/viewNotes.php?buildid=3681627 [^]) to see what might be different from your setup. If you can get around it, please close this bug. If not, add more to the report to help track it down. |
(0034174) Nicholas Yue (reporter) 2015-02-05 12:57 |
As it would require that I upgrade (1) OS X (mine is 10.10, dashboard is 10.10.2) (2) XCode (mine is 6.1 (6A1052d), dashboard is 6.1.1 (6A2008a) (3) clang (mine is clang-600.0.54, dashboard is clang-600.0.56 ) I will close this for now as it seems the fixes are most likely Apple's update. I'll leave this note here as I can't find a button which allows me to close this bug. |
2014-12-10 05:26 | Nicholas Yue | New Issue | |
2015-02-05 12:19 | Dave DeMarle | Note Added: 0034164 | |
2015-02-05 12:57 | Nicholas Yue | Note Added: 0034174 | |
2015-02-05 14:14 | Jean-Christophe Fillion-Robin | Status | backlog => closed |
2015-02-05 14:14 | Jean-Christophe Fillion-Robin | Assigned To | => Jean-Christophe Fillion-Robin |
2015-02-05 14:14 | Jean-Christophe Fillion-Robin | Resolution | open => no change required |
2015-02-05 14:14 | Jean-Christophe Fillion-Robin | Fixed in Version | => 6.2.0 |
