| 0014130 | VTK | (No Category) | public | 2013-06-17 11:27 | 2013-07-22 19:37 | ||||
| Reporter | Sebastien Jourdain | ||||||||
| Assigned To | Sebastien Jourdain | ||||||||
| Priority | low | Severity | minor | Reproducibility | have not tried | ||||
| Product Version | 6.0.rc | ||||||||
| Target Version | Fixed in Version | 6.0.0 | |||||||
| Summary | 0014130: JAVA: No callback available when window is ready to custom settings | ||||||||
| Description | Some window/renderer/interactor method calls require an opengl context and if those methods are called before the render window is embedded inside a UI component in Java, a floating window get created and with bad luck that can even crash your application. Normally those changes should be achieved once the view is properly created and a flag is available to know when such changes can be achieved. Although, no callback mechanism are provided. This patch, allow to set callback once the window gets properly created. | ||||||||
| Project | Kitware | ||||||||
| Type | feature | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
| There are no notes attached to this issue. |
| Notes |
| Issue History | |||
| 2013-06-17 11:27 | Sebastien Jourdain | New Issue | |
| 2013-06-17 11:27 | Sebastien Jourdain | Status | backlog => tabled |
| 2013-06-17 11:27 | Sebastien Jourdain | Assigned To | => Sebastien Jourdain |
| 2013-06-17 11:27 | Sebastien Jourdain | Status | tabled => gatekeeper review |
| 2013-06-17 11:27 | Sebastien Jourdain | Resolution | open => fixed |
| 2013-07-22 19:37 | Dave DeMarle | Status | gatekeeper review => closed |
| 2013-07-22 19:37 | Dave DeMarle | Fixed in Version | => 6.0.0 |
| Issue History |
