0013892ParaView(No Category)public2013-02-19 04:092013-09-03 21:29
ReporterMaxim
Assigned ToYumin Yuan
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version3.98.1
Target VersionFixed in Version4.0
Summary0013892: Does not draw polyhedrons when polyhedrons placed in several piaces in vtu file
DescriptionWhen I use polyhedron cells (type 42) in one piece of vtu file in
ParaView-3.98.1-Windows-64bit all is right. Such example you can see in attached
tar archive(file1.vtu). But when I use polyhedron cells (type 42) in several
pieces in vtu file ParaView does draws polyhedrons only from the first piece and does not draw polyhedrons from the other pieces. You can see the simple example in attached tar archive(file2.vtu). Also when I tried to load big vtu file with polyhedrons in several pieces ParaView crashes.
TagsNo tags attached.
ProjectParaViS
Topic Name13892_polyhedron_vtu
Typecrash
Attached Filestar file icon files.tar [^] (6,656 bytes) 2013-02-19 04:09
? file icon polyhedron2pieces.vtu [^] (2,483 bytes) 2013-04-18 10:02
 Relationships
related to 0014188closedDavid Thompson Bug on clipping vtkUnstructuredGrid containing Polyhedrons
  Notes
(0030577)
Yumin Yuan (developer)
2013-04-18 10:01
There are two places wrong for this bug. First is a real bug in the reader itself; second is that the file attached also contains some errors. Please use the new attached file (polyhedron2pieces.vtu) to test for the bug fix.
(0030610)
2013-04-25 09:24
SUMMARY
Topics merged into master:
        13450_update_tests_to_use_new_panels
(VTK) 14023-plot3d-function-support
        14026_catalyst_python_warning
        14032_fix_CoProcessingTestInput
        fix_protobuf_try_compiles
        pvw-python-refactoring
        pvw-remove-example
        refactor_panels
(VTK) update_vtk_master
        zoom-to-data-icon
        fix_cmake_2.8.10_plugins_issue
(0031533)
Alan Scott (manager)
2013-09-03 21:29
I believe this was actually fixed in bug 14188.
Tested Linux, master, local server.
 (Remote server crashes, bug number http://paraview.org/Bug/view.php?id=14258. [^])
 Issue History
2013-02-19 04:09 Maxim New Issue
2013-02-19 04:09 Maxim File Added: files.tar
2013-03-12 09:13 Utkarsh Ayachit Status backlog => todo
2013-04-10 12:51 Utkarsh Ayachit Assigned To => Yumin Yuan
2013-04-11 08:40 Yumin Yuan Status todo => active development
2013-04-18 10:01 Yumin Yuan Topic Name => 13892_polyhedron_vtu
2013-04-18 10:01 Yumin Yuan Note Added: 0030577
2013-04-18 10:01 Yumin Yuan Status active development => gatekeeper review
2013-04-18 10:01 Yumin Yuan Fixed in Version => git-next
2013-04-18 10:01 Yumin Yuan Resolution open => fixed
2013-04-18 10:02 Yumin Yuan File Added: polyhedron2pieces.vtu
2013-04-25 09:22 Utkarsh Ayachit Fixed in Version git-next => git-master
2013-04-25 09:24 Utkarsh Ayachit Note Added: 0030610
2013-04-25 09:24 Utkarsh Ayachit Status gatekeeper review => customer review
2013-05-18 20:00 Utkarsh Ayachit Fixed in Version git-master => 4.0
2013-09-03 21:28 Alan Scott Relationship added related to 0014188
2013-09-03 21:29 Alan Scott Note Added: 0031533
2013-09-03 21:29 Alan Scott Status customer review => closed
