MantisBT - ParaView | |||||
| View Issue Details | |||||
| 0012286 | ParaView | Feature | public | 2011-06-20 16:35 | 2012-02-08 17:28 |
| Reporter | David Partyka | ||||
| Assigned To | David Partyka | ||||
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | fixed | ||
| Product Version | |||||
| Target Version | 3.12 | Fixed in Version | 3.14 | ||
| Project | Kitware | ||||
| Topic Name | 12286-integrate-nektar-plugin | ||||
| Type | feature | ||||
| Summary | 0012286: Integrate Nektar Plugin into ParaView | ||||
| Description | Integrate building Nectar plugin and it's dependencies. > Hi Joe, > this is great! thanks for getting Berk involved. > Re: PARALLEL - i think we will not have issues or may be only minor ones, > and sequential version will be built relatively easy. > Re BLAS/LAPACK: > we can replace calls to BLAS level 1,2 and 3 with some simple routines that > will do linear algebra. > with LAPACK routines we will have to build LU factorization functions, > linear solvers, eigenvalue solvers. this is possible but i do not think it > is a good idea mainly for two reasons: > a) BLAS and LAPACK are free libraries that can be downloaded and installed > easily. > b) this will limit (or make difficult) developing future versions of our > plug-in as we would like to utilize as much as we can what is already > existing in Nektar. also Nektar's users (potential customers) can create > they own utilities and keep the same style as used in Nektar already and > assume that BLAS and LAPACK are available. > lets see what Berk can suggest, it might be that they also have some subset > of BLAS/LAPACK built-in. > Leopold > > > > > On Thu, Mar 10, 2011 at 6:42 PM, joseph insley <insley@mcs.anl.gov> wrote: >> >> Hey, Leo, >> >> I have made a PV_NEKTAR tarball, which I believe includes the minimum >> necessary code from Nektar-PARALLEL, and the actual reader plugin code. And >> wrote a short README file explaining how to build the various components. >> While doing this I took note of a few issues that will need to be addressed >> at some point. (Sooner rather than later, will be better) >> >> External dependencies: >> Blas >> Lapack >> gfortran >> >> I don't know whether these should be included in the distribution, or >> users will need to have these installed separately, or what. I'm hoping >> Berk can provide some guidance on that. >> >> MPI: >> Currently I have only been building all of the components (both Nektar and >> the plugin itself) assuming that it will be parallel. This means, I >> believe, that the reader can only work in client/server mode. Also, I >> believe that binary distributions of PV do not include MPI builds. Users >> will need to compile from source in order to get the parallel version. If >> we want users to be able to run standalone ParaView, on their laptop or >> local workstation, for example, and use the Nektar reader plugin, I think we >> are going to need to support a non-parallel version. I remember early on in >> our development, while you were visiting ANL if I remember correctly, we >> touched on this issue briefly, and decided to punt on it initially, and >> worry about it later. I think now may be the time that we need to start >> worrying about it. I will try building everything without PARALLEL=1 and >> see how far I get. But I suspect that I will run into problems before too >> long. When (if?) I do get stuck, I will poke you for help in resolving. I >> just wanted to give you a heads-up about it. >> >> joe. > > | ||||
| Steps To Reproduce | |||||
| Relationships | |||||
| Attached Files | https://www.vtk.org/Bug/file/9046/PV_NEKTAR.tar.gz | ||||
| Issue History | |||||
| 2011-06-20 16:35 | David Partyka | New Issue | |||
| 2011-06-20 16:35 | David Partyka | Assigned To | => David Partyka | ||
| 2011-06-22 13:54 | Berk Geveci | Target Version | => 3.12 | ||
| 2011-09-29 12:45 | David Partyka | Status | backlog => todo | ||
| 2011-09-29 12:45 | David Partyka | Status | todo => active development | ||
| 2011-10-15 11:21 | David Partyka | File Added: PV_NEKTAR.tar.gz | |||
| 2011-12-07 17:03 | David Partyka | Topic Name | => 12286-integrate-nektar-plugin | ||
| 2011-12-07 17:03 | David Partyka | Status | active development => gatekeeper review | ||
| 2011-12-07 17:03 | David Partyka | Fixed in Version | => git-next | ||
| 2011-12-07 17:03 | David Partyka | Resolution | open => fixed | ||
| 2011-12-09 14:20 | Utkarsh Ayachit | Status | gatekeeper review => customer review | ||
| 2011-12-09 14:20 | Utkarsh Ayachit | Note Added: 0027787 | |||
| 2011-12-09 14:21 | Utkarsh Ayachit | Fixed in Version | git-next => git-master | ||
| 2012-02-08 17:21 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 | ||
| 2012-02-08 17:28 | Utkarsh Ayachit | Status | customer review => closed | ||
| 2012-02-08 17:28 | Utkarsh Ayachit | Note Added: 0028236 | |||
| Notes | |||||
